| Message |
Pressure test the system and cap, check/seal the shroud, check the splash shield, check for debri blocking the radiator, check for debri in the radiator, check the fan clutch. Is it getting hot while cruising? or just plain getting hot whenever you drive it? If you still looking for a radiator, I did this when my second new fan exploded and took out the radiator and second new shroud. It's nearly a completely bomb proof setup, but requires some finagling to get it in there and fab up mounts, hoses..etc (not for the faint of heart)
